Streamteam
#1 Posted : Monday, December 14, 2020 4:47:05 AM(UTC)
Streamteam
Is it possible to assign a shortcut key to enable/disable the web controller?
For a church service, I have lyrics, scripture, etc in a PowerPoint and capturing it as NDI input. I wrote a VBA routine for PowerPoint to sent web API commands to turn the PowerPoint NDI overlays on and off at particular slides.
I would like to assign a shortcut key as a “kill switch” for the web controller in case things go haywire, it’s quick to take over manual control. Any ideas?
#2 Posted : Monday, December 14, 2020 5:24:12 AM(UTC)
Would it not make more sense to build that into your routine ?
If you say its quick to take over manually why not deactivate the web controller manually ?
