Rinsky
#1 Posted : Thursday, December 3, 2020 10:55:37 AM(UTC)
Rinsky
I think I already managed to make it work, but now it seems not to work anymore.
I would like to use the recorded mode also as "kinda live" mode. So if I use the "jump to now" shortcut, I also want to use a "ReplayPlay" shortcut at the same time. Sometimes it works, but sometimes it just gets stuck. The problem is of course that I can't play liveo videomaterial in in realtime while it's recording.
The thing I would need is a little delay for the "ReplayPlay" shortcut.
Any ideas on how to solve this? Any workarounds?
I also tried this script, but it still stops frome time to time instead of playing forward:
Input.Find("Replay - A").Function("ReplayJumptoNow")
Sleep(0)
Input.Find("Replay - A").Function("ReplaySetDirectionForward")
Sleep(50)
Input.Find("Replay - A").Function("ReplayPlay")
I also tried higher sleep times
dmwkr
#2 Posted : Saturday, December 12, 2020 7:13:43 PM(UTC)
dmwkr
Was thanked: 160 time(s) in 144 post(s)
What sleep times did you try? My guess is to try 2000ms and then work your way down to find out what is possible.
