Instant Replay
Jump to now + Play Shortcut
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
I think I already managed to make it work, but now it seems not to work anymore.
I would like to use the recorded mode also as "kinda live" mode. So if I use the "jump to now" shortcut, I also want to use a "ReplayPlay" shortcut at the same time. Sometimes it works, but sometimes it just gets stuck. The problem is of course that I can't play liveo videomaterial in in realtime while it's recording.
The thing I would need is a little delay for the "ReplayPlay" shortcut.
Any ideas on how to solve this? Any workarounds?
I also tried this script, but it still stops frome time to time instead of playing forward:
Input.Find("Replay - A").Function("ReplayJumptoNow") Sleep(0) Input.Find("Replay - A").Function("ReplaySetDirectionForward") Sleep(50) Input.Find("Replay - A").Function("ReplayPlay")
I also tried higher sleep times
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
What sleep times did you try? My guess is to try 2000ms and then work your way down to find out what is possible.
Instant Replay
