Hi all i am trying to add file from my local PC to A List input by this Command http://MYIP:MYPORT/api/?Function=ListAdd=test.jpg&Input=10 but I get An error No suitable Function could be found. can anyone direct me how to make it work?
Use a full path address for your file...
Like D:\folder\sub-folder\file.ext
Joined: 8/5/2017(UTC) Posts: 582  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
I think you also need to put the filename in the Value (untested). Something like the following..
http://MYIP:MYPORT/api/?Function=ListAdd&Input=10&Value=D:\folder\sub-folder\file.ext
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: raugert  I think you also need to put the filename in the Value (untested). Something like the following..
http://MYIP:MYPORT/api/?Function=ListAdd&Input=10&Value=D:\folder\sub-folder\file.ext hi raugert i need a webapi to resolve full pah of inputs any any help here ? as Doggy Said Here i got the basic way but its not full path. https://forums.vmix.com/...nd-file-name-via-wep-apitnx alot
