Facebook Live 1080p Not Working
Joined: 9/7/2020(UTC) Posts: 15  Location: Perkinston
I am using the Facebook settings in vMix 4K 23.0.0.66 to stream our church services. I've only be able to get a 1080p broadcast to work once even though I am sending the 1080p preset for FB. It automatically downgrades it to 720p. Is there some setting in FB that I need to adjust?
Thanks.
Brian
Joined: 11/23/2020(UTC) Posts: 2  Location: Ballymena Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: bscarbrough1903  I am using the Facebook settings in vMix 4K 23.0.0.66 to stream our church services. I've only be able to get a 1080p broadcast to work once even though I am sending the 1080p preset for FB. It automatically downgrades it to 720p. Is there some setting in FB that I need to adjust?
Thanks.
Brian Hi Brian - having made the same mistake, I know the answer to this one! :) Facebook will not allow you to stream at 1080 unless you are part of the Level Up Programme - further info here - https://www.facebook.com...77882?id=648321075955172
Joined: 4/23/2017(UTC) Posts: 1,490  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Yes, I've seen the level up program, but why would it on one day allow me to stream at 1080p and then stop? Seems strange. And I don't understand why I need to convert to what looks like a gaming page?
Joined: 11/24/2020(UTC) Posts: 1  Location: New Jersey
I was looking for the same info, tried doing the same but it didn't worked. Thanks for spreading the knowledge tellthebell!
Joined: 8/11/2017(UTC) Posts: 7  Was thanked: 1 time(s) in 1 post(s)
Create your FB stream using the vmix API, this method allows FB to accept a 1080p stream.
If you create your stream with the FB landing page, it will only allow streams up to 720p.
I am using the vMix Facebook destination option where I login to facebook from vMix and specify Quality at 1080p 6mbps. Then just click Stream. Or are you talking about using a custom RTMP Server method?
I tried using the Custom RTMP method as well, same result. Facebook sees I'm sending 1080, but resolution is capped at 720. I see messages in the Event Log about that.
Originally Posted by: bscarbrough1903  I am using the vMix Facebook destination option where I login to facebook from vMix and specify Quality at 1080p 6mbps. Then just click Stream. Or are you talking about using a custom RTMP Server method?
I tried using the Custom RTMP method as well, same result. Facebook sees I'm sending 1080, but resolution is capped at 720. I see messages in the Event Log about that. Yes, Use the vMix Facebook destination option where you login to facebook from vMix and specify Quality at 1920 x 1080 6mbps. Also, Make sure your input sources, master output size / frame rate, and external output 1 is set to 1920x1080 / ntsc 29.97p and double check you are using the latest vmix version(23) It's possible that facebook is blocking 1080 streaming in you area.
Yes, Matt, that is exactly what I am doing. I think you are right. I have seen 1080p stream a couple times, but generally it just drops to 720p.
So, I signed up for the Level Up Program which basically means adding the Gaming Video Creator tag to your page. I have qualified for 4 of the 6 requirements so we'll see if I can get all 6 and can up my stream rate to 1080p. Facebook did say they recommend I use 30fps rather than 29.97, so I changed that.
