Chris Daum
#1 Posted : Thursday, December 3, 2020 7:58:48 PM(UTC)
Chris Daum
Germany
Hi Together,
I just came about the Multi View Issue.
I couldn´t find a suitable selection for my Multiview Needs i.e.
PRV Mix 2 these are my sends to Signal Management device (Aquilon)
PRV Mix 3
PRV Out 3 return picture for my Callers
PRV Call 1-4
So I arranged all the feeds on a blank Virtual Input
Layer 1 Multiview Frame with Titles
Layer 2 Mix2
aso...
That worked well and looks quite professional
bat, of course was a bit of an effort.
Anybody a better Idea or hint?
Thanks for advice in advance!!!
Greetz
Chris
#2 Posted : Thursday, December 3, 2020 8:00:53 PM(UTC)
Something specific/special/personalized always demands a little bit of effort ;-)
Chris Daum
#3 Posted : Thursday, December 3, 2020 8:04:54 PM(UTC)
Chris Daum
Germany
@ doggy, which is absolutely clear!! :-)
just found this topic from 2014, obviously there has not been a solution.
So I keep on customizing :-)
Originally Posted by: curtismacd31 Go to Quoted Post
I know this has been touched on before, I would like to see more Multiviewer layout options for fullscreen output. similar to what is found in the Tricaster.
#4 Posted : Thursday, December 3, 2020 8:23:37 PM(UTC)
you can have way more layouts because you can create them ;-)
elvis55 on 12/3/2020(UTC)
Chris Daum
#5 Posted : Thursday, December 3, 2020 9:49:11 PM(UTC)
Chris Daum
Germany
luckily you can add a finished and working layout to the general MV layouts...
Chris Daum
#6 Posted : Thursday, December 3, 2020 10:20:14 PM(UTC)
Chris Daum
Germany
@doggy
you see any chance to preview the Prievies of Mix2/3?
#7 Posted : Thursday, December 3, 2020 10:45:11 PM(UTC)
Originally Posted by: Chris Daum Go to Quoted Post
@doggy
a Mix is a input on its own so not directly
but the API XML an tell you which input in the MIX is in preview or output in that mix so use that info to preview that input referenced (script)
Chris Daum on 12/3/2020(UTC)
