Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
Hi Together,
I just came about the Multi View Issue.
I couldn´t find a suitable selection for my Multiview Needs i.e.
PRV Mix 2 these are my sends to Signal Management device (Aquilon) PRV Mix 3 PRV Out 3 return picture for my Callers PRV Call 1-4
So I arranged all the feeds on a blank Virtual Input Layer 1 Multiview Frame with Titles Layer 2 Mix2 aso...
That worked well and looks quite professional bat, of course was a bit of an effort.
Anybody a better Idea or hint?
Thanks for advice in advance!!!
Greetz Chris
Joined: 12/27/2012(UTC) Posts: 5,500  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
Something specific/special/personalized always demands a little bit of effort ;-)
@ doggy, which is absolutely clear!! :-) just found this topic from 2014, obviously there has not been a solution. So I keep on customizing :-) Originally Posted by: curtismacd31  I know this has been touched on before, I would like to see more Multiviewer layout options for fullscreen output. similar to what is found in the Tricaster.
you can have way more layouts because you can create them ;-)
luckily you can add a finished and working layout to the general MV layouts...
@doggy you see any chance to preview the Prievies of Mix2/3?
Originally Posted by: Chris Daum  @doggy you see any chance to preview the Prievies of Mix2/3? a Mix is a input on its own so not directly but the API XML an tell you which input in the MIX is in preview or output in that mix so use that info to preview that input referenced (script)
