How to use Shortcuts with Mix inputs
Joined: 11/10/2020(UTC) Posts: 2 ![Spain Spain](/Content/images/flags/ES.png) Location: Valencia
Hi there,
I'm trying to understand how to call a transition in a Mix input using shortcuts. The vMix user guide says:
The following shortcuts can be used with an optional Mix parameter, where 1 is equal to the main mix in vMix and 2 is equal to the first Mix input.
PreviewInput ActiveInput Fade, Zoom, Wipe etc
If I have a Mix input with layer 5 on Preview and layer 6 on Output, which would be the shortcut to FADE/MERGE/CUT between them instead of having to click with my mouse on the button right next to the Mix input?
Thank you!
Joined: 10/5/2020(UTC) Posts: 9 ![United Kingdom United Kingdom](/Content/images/flags/GB.png) Location: Plymouth
Originally Posted by: RickBrock ![Go to Quoted Post Go to Quoted Post](/Themes/yafpro/icon_latest_reply.gif) I'm sorry. I mean that I want to know how to write the function that will result in: If I have a Mix input with layer 5 on Preview and layer 6 on Output, which would be the shortcut function to FADE/MERGE/CUT between them instead of having to click with my mouse on the button right next to the Mix input?Just like I can change AudioBuses values using this: AudioBusOn Value=M&Input=21 (just an example of a function)
Joined: 12/27/2012(UTC) Posts: 5,322 ![Belgium Belgium](/Content/images/flags/BE.png) Location: Belgium Thanks: 299 times Was thanked: 979 time(s) in 812 post(s)
Quote:I'm sorry. I mean that I want to know how to write the function that will result in: If I have a Mix input with layer 5 on Preview and layer 6 on Output, which would be the shortcut function to FADE/MERGE/CUT between them instead of having to click with my mouse on the button right next to the Mix input? It always helps to be clear in asking questions! you will need to write a script in order to check and decide what to do when your options are set and have a (existing) function perform the task you want to happen. This is NOT what the title of the post implies at all. Functions have the same basic structure as what has to be defined when creating a shortcut Search this forum for scripting
Joined: 3/7/2012(UTC) Posts: 2,654 ![Man Man](/Themes/yafpro/male.gif) Location: Canada Thanks: 33 times Was thanked: 508 time(s) in 477 post(s)
@ samermachine The Shortcuts to use are the same as for the main vMix Output mix, you simply need to select from the dropdown which mix the Shortcut applies to when creating the Shortcut. Mix 1 = Main vMix Output mix Mix 2 = 1st sub-mix "Mix" Input Mix 3 = 2nd sub-mix "Mix" Input Mix 4 = 3rd sub-mix "Mix" Input https://www.vmix.com/help23/Mix.htmlIce
Thanks: 62 times Was thanked: 134 time(s) in 122 post(s)
I think what might be confusing (at least as confusing as your combination of post title and post ;-) )is that the Main Mix ("Mix 1") is Mix=0 in scripting, "Mix 2" is Mix=1 in scripting...
So, for Mix 2: Function=Cut&Mix=1
