samermachine
#1 Posted : Thursday, November 19, 2020 8:24:46 PM(UTC)
samermachine
Spain
Hi there,
I'm trying to understand how to call a transition in a Mix input using shortcuts. The vMix user guide says:
The following shortcuts can be used with an optional Mix parameter, where 1 is equal to the main mix in vMix and 2 is equal to the first Mix input.
PreviewInput
ActiveInput
Fade, Zoom, Wipe etc
If I have a Mix input with layer 5 on Preview and layer 6 on Output, which would be the shortcut to FADE/MERGE/CUT between them instead of having to click with my mouse on the button right next to the Mix input?
Thank you!
RickBrock
#2 Posted : Thursday, November 19, 2020 8:39:52 PM(UTC)
RickBrock
If I understand you right.... then do this to set up your own shortcut key....
1) click settings (top right)
2) click 'shortcuts'(on the left of the box)
3) click add
then follow it from there.....
https://www.vmix.com/hel...index.htm?Shortcuts.html
samermachine
#3 Posted : Thursday, November 19, 2020 8:47:12 PM(UTC)
samermachine
Spain
3) click add
I'm sorry. I mean that I want to know how to write the function that will result in: If I have a Mix input with layer 5 on Preview and layer 6 on Output, which would be the shortcut function to FADE/MERGE/CUT between them instead of having to click with my mouse on the button right next to the Mix input?
Just like I can change AudioBuses values using this: AudioBusOn Value=M&Input=21 (just an example of a function)
#4 Posted : Thursday, November 19, 2020 9:05:04 PM(UTC)
It always helps to be clear in asking questions!
you will need to write a script in order to check and decide what to do when your options are set and have a (existing) function perform the task you want to happen. This is NOT what the title of the post implies at all.
Functions have the same basic structure as what has to be defined when creating a shortcut
Search this forum for scripting
#5 Posted : Thursday, November 19, 2020 11:35:27 PM(UTC)
@ samermachine
The Shortcuts to use are the same as for the main vMix Output mix, you simply need to select from the dropdown which mix the Shortcut applies to when creating the Shortcut.
Mix 1 = Main vMix Output mix
Mix 2 = 1st sub-mix "Mix" Input
Mix 3 = 2nd sub-mix "Mix" Input
Mix 4 = 3rd sub-mix "Mix" Input
https://www.vmix.com/help23/Mix.html
dmwkr
#6 Posted : Friday, November 20, 2020 7:33:39 AM(UTC)
dmwkr
Was thanked: 160 time(s) in 144 post(s)
I think what might be confusing (at least as confusing as your combination of post title and post ;-) )is that the Main Mix ("Mix 1") is Mix=0 in scripting, "Mix 2" is Mix=1 in scripting...
So, for Mix 2:
Function=Cut&Mix=1
CyaSteve
#7 Posted : Friday, June 6, 2025 3:41:42 AM(UTC)
CyaSteve
5 years later but since I'm doing this right now with a streamdeck here's how I'm doing it with shortcuts.
My Mix2 is what I'm targeting here to switch between the two inputs. When this is triggered it takes whatever is in Mix2's preview and cuts it to Mix2's output, and puts what was in output to preview.
Screenshot 2025-06-05 104051.png (101kb) downloaded 32 time(s).
thanks 2 users thanked CyaSteve for this useful post.
timolinsei on 6/24/2025(UTC), theonlyrealnickarnold on 7/6/2026(UTC)
