Action against YouTube no longer supporting 25/50fps
Lukas Herzog from Mainz, Germany raised a question at YouTube's community forum about frame duplication on youtube when streaming 25/50p, which is very annoying from a PAL perspective and was discussed a few weeks ago in this vMix forum too. Perhaps you could vote it up a little and if someone has a more direct route to the YouTube support could raise it there as well? Here's the link to add your +1 https://support.google.c...be/thread/83656186?hl=enGuillaume, aka DWAM, on behalf of Lukas
 3 users thanked DWAM for this useful post.
 1 user thanked richardgatarski for this useful post.
Thanks Richard !
I really hope we have a lot of support on this
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
Done. I also never figured out why youtube saves the VOD of streams at 30p for me (and some others) while some other channels seem to be forced to 30p for the live but their VODs are at 25p. Hopefully if they fix the stream framerate it will sort out the VODs as well.
 1 user thanked RichDanby for this useful post.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
 1 user thanked dmwkr for this useful post.
Joined: 5/27/2017(UTC) Posts: 93   Location: Greater St Louis Area Thanks: 67 times Was thanked: 20 time(s) in 13 post(s)
I've "done the needful thing", DWAM... thanks for linking regarding the matter.
 1 user thanked clafarge for this useful post.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
Upvoted, but you should change 60Hz to 50Hz in the description.
"Streaming in 30 or 60 often is not an option since many countries have a mains frequency of 60 Hz and you'll get light flicker issues when doing 30 or 60p."
60Hz and 30/60p will not generate flicker, 50Hz and 30/60p or 60Hz and 25/50p will.
 1 user thanked MartLeib for this useful post.
Quote: you should change 60Hz to 50Hz in the description As explained, I'm not the author of this poston YT blog so unfortunately I have no control over the content. But you got the idea anyway...
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Upvoted Hope you get many votes and likes for this. telldunkin
Thanks: 21 times Was thanked: 11 time(s) in 9 post(s)
I have upvoted too. Actually, I posted on the community site as well, before I found yours here.
This is annoying. If VOD then Youtube enc at the video rate, 25, 30, 50 or 60etc. But Live is only 30 or 60, resulting in jumpy stream. Why won't they listen ?
If anyone has a workaround, it would be great. I tried streaming at 60, but as the camera input is 50, letting vmix do the conversion, but the jumpy frames were worse.
