Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
I have a youtube livestream input but compared to the same stream in a browser I do not seem to get this same stream to play as smoothly in vMix.
As result a recording etc is not smooth either.
Is this a vMix 'issue' ?
any tips ?
Guy
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Does the frame rate in vMix match the stream?
Martin vMix
HI Martin from what I could figure out the stream was/is 30 fps (1280x720) Same settings in vMix (ntsc)
For some reason the latest YouTube player only works at 10fps when used outside of a browser (such as in vMix). You can use the direct embed URL as shown below with the version 2 player which works ok: http://www.youtube.com/v...start=1335&version=2Note however that YouTube may change this at any time, which is why it is not supported by vMix. It is always better to download the videos first if possible. Regards, Martin vMix
Thank you Martin
while it was live (the last day) I switched to displaying it on second monitor and did screen capture. Better but then getting the sound was a PITA
Normally would download too (later) but a over 11hr video is a bit much ;-)
PS
Dont seem to be able to force the HD version
