#1 Posted : Monday, March 10, 2014 7:54:40 AM(UTC)
I have a youtube livestream input but compared to the same stream in a browser I do not seem to get this same stream to play as smoothly in vMix.
As result a recording etc is not smooth either.
Is this a vMix 'issue' ?
any tips ?
Guy
#2 Posted : Monday, March 10, 2014 11:30:55 PM(UTC)
Does the frame rate in vMix match the stream?
#3 Posted : Tuesday, March 11, 2014 5:31:13 AM(UTC)
HI Martin
from what I could figure out the stream was/is 30 fps (1280x720)
Same settings in vMix (ntsc)
#4 Posted : Tuesday, March 11, 2014 7:57:25 AM(UTC)
For some reason the latest YouTube player only works at 10fps when
used outside of a browser (such as in vMix).
You can use the direct embed URL as shown below with the version 2 player which works ok:
http://www.youtube.com/v...start=1335&version=2
Note however that YouTube may change this at any time, which is why it is not supported by vMix.
It is always better to download the videos first if possible.
#5 Posted : Tuesday, March 11, 2014 8:30:21 AM(UTC)
Thank you Martin
while it was live (the last day) I switched to displaying it on second monitor and did screen capture. Better but then getting the sound was a PITA
Normally would download too (later) but a over 11hr video is a bit much ;-)
#6 Posted : Tuesday, March 11, 2014 9:16:35 AM(UTC)
PS
Dont seem to be able to force the HD version
