vMix Call
Using the same login details
Joined: 8/16/2019(UTC) Posts: 355  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Hi all, I have a laptop that I want to leave on at a location with the webcam and audio on, I then want to connect the call to vMix once I get back home.
The only problem I have is that I can't be at two locations at the same time to setup!
I've tested, but no luck (unless I press refresh on the laptop browser and it works, but I can't be there to refresh - unless I keep driving back and forth), would someone know of another way.
Sadly I don't have a port number (I have the IP address) to connect to but the IT guys won't open a port (hence vMix Call) for me to use TCP.
Any advice/suggestions would be great.
Joined: 4/23/2017(UTC) Posts: 1,476  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Yes sure. Multiple options. -Use SRT out from mix. This runs once vmix is started. -Use a remote Desktop App like Teamviewer, PCVisit, Anydesk, VNC.... to control the far end. Even Chrome has remote support build in. https://remotedesktop.google.com/-Use some other software that allows to remote manage the caller at the far end. Something like medialooks VT tools. They have a VT admin interface that you can use to connect any avilable source to any available destination. Like a video matrix.
 1 user thanked mavik for this useful post.
vMix Call
