Simsyuk
#1 Posted : Wednesday, November 18, 2020 3:11:05 AM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Hi all, I have a laptop that I want to leave on at a location with the webcam and audio on, I then want to connect the call to vMix once I get back home.
The only problem I have is that I can't be at two locations at the same time to setup!
I've tested, but no luck (unless I press refresh on the laptop browser and it works, but I can't be there to refresh - unless I keep driving back and forth), would someone know of another way.
Sadly I don't have a port number (I have the IP address) to connect to but the IT guys won't open a port (hence vMix Call) for me to use TCP.
Any advice/suggestions would be great.
mavik
#2 Posted : Wednesday, November 18, 2020 4:21:07 AM(UTC)
mavik
Yes sure. Multiple options.
-Use SRT out from mix. This runs once vmix is started.
-Use a remote Desktop App like Teamviewer, PCVisit, Anydesk, VNC.... to control the far end. Even Chrome has remote support build in. https://remotedesktop.google.com/
-Use some other software that allows to remote manage the caller at the far end. Something like medialooks VT tools. They have a VT admin interface that you can use to connect any avilable source to any available destination. Like a video matrix.
Simsyuk on 11/18/2020(UTC)
