Feature Requests
Preview window option to ... Show 'next' input
My production is built for volunteers to run, so I have a sequence of about 100 inputs that people will step through (desired: Quick Play, Quick Play, ...). Current behavior is that Active input is moved into Preview when transition happens, so this easy-click 'next' scenario doesn't work out of the box.
I'm using a workaround which is putting 2 triggers on each and every input: PreviewInput > Active PreviewInputNext This accomplishes getting the 'next' input into the Preview window, but (1) there's a lot of input flashing in the preview window as each transition causes 3 changes to Preview; (2) delays need to be added to the triggers for this to work right; and (3) frankly, it's also a pain adding these triggers to each input.
It would be lovely if there were a global option that controls what goes to Preview: Active (current behavior - Active and Preview are swapped) ActiveNext (i.e., whatever the 'next' input is after a transition occurs) This would make it so easy to just click (transition) sequentially through all the inputs.
You might wonder why I don't use a manual PlayList. Answer: There are unpredictable times when it is needed to transition to an input that's out of sequence...because people on camera aren't perfect. Jumping around in a PlayList isn't really convenient, and requires 4 steps (Stop / Select desired input / check 'begin from selected item' / Start).
If you’re still looking for a way to do this, we use a simple vMix script called PreviewNext. After each transition, it automatically puts the next input into Preview, so you can keep stepping through your inputs while still jumping to another input when needed. The latest script code is on GitHub: github.com/live-miracles/vmix-master/blob/master/vmix-scripts/preview-next.vbThe raw code: Code:' Script name: PreviewNext
' Automatically puts the next input into preview after each transition.
' If the active input is the last one, vMix will ignore the out-of-range preview request gracefully.
' ===== Configurations =====
Dim LOOP_TIME As Integer = 300 ' Poll interval in ms
Dim DELAY_TIME As Integer = 1000 ' How long to wait after a transition before updating preview
' --- VERSION CHECK ---
Dim SCRIPT_NAME As String = "preview-next"
Dim SCRIPT_VERSION As String = "1.0.1"
Dim timestamp As String = DateTime.Now.ToString("HH:mm:ss")
Console.WriteLine(timestamp & " PreviewNext " & SCRIPT_VERSION)
Dim lastActive As String = ""
Dim xml As New System.Xml.XmlDocument()
Do While True
Sleep(LOOP_TIME)
Try
xml.LoadXml(API.XML())
Dim active As String = xml.SelectSingleNode("//active").InnerText
If lastActive <> active Then
Sleep(DELAY_TIME)
lastActive = active
Dim nextInput As String = CStr(CInt(lastActive) + 1)
timestamp = DateTime.Now.ToString("HH:mm:ss")
Console.WriteLine(timestamp & " PreviewNext | Updating preview: " & nextInput)
API.Function("PreviewInput", Input:=nextInput)
Continue Do
End If
Catch ex As Exception
Console.WriteLine(timestamp & " PreviewNext | Unexpected error: " & ex.Message)
End Try
Loop
Feature Requests
