I have vMix on 2 PCs, when its running, I can take the feed from one vMix and use it on the other using NDI. Is there a way for another device to watch only that NDI feed, like using a web browser or an app? My goal is to take the feed and watch it from a couple tablets (Android OS).
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
To watch it on another system. There is the NDI monitor application that is part of the NDI tools. Fot the IOS devics there is NDI Viewer But keep im mind that NDI is network intensive. And the advice is not to run it on wifi. It is not a solution that should be used for a digitial signage solution. Better is to push rtmp out. And use a rtmp server to distribute in your network: Like is described here https://garaninapps.com/...er-differs-from-other-se
