jsandytn
#1 Posted : Wednesday, November 11, 2020 10:59:25 PM(UTC)
jsandytn
I have the 4K version of vMix and I use scripting. Scripting does not recognize a command to set text in headings. The expected script command would be: API.Function("SetText", Input:="View_Selected_Parameters.gtzip",Title:="Camera.Text",Value="Cam1"). Using this in a script produces the error: BC30451: Name 'Value' is not declared.
Is there a command to change headings using the API call in a script? If so, what is the command?Error Message-API command for Set Title
#2 Posted : Thursday, November 12, 2020 12:45:56 AM(UTC)
There is definitely a bug but it's not vMix ;-)
If formulated correctly like how it's mentioned in the helpfiles WILL let vMix recognize it
also no need to post the same thing twice
API.Function("SetText",Input:="some.gtzip",SelectedName:="Headline.Text",Value:="Some Text")
MichaelOlsen
#3 Posted : Thursday, November 12, 2020 2:06:12 AM(UTC)
MichaelOlsen
Denmark
Don't you miss a ":" after the "Value" - "Value:=" instead of "Value="
