Script API command for setting titles?
I have the 4K version of vMix and I use scripting. Scripting does not recognize a command to set text in headings. The expected script command would be: API.Function("SetText", Input:="View_Selected_Parameters.gtzip",Title:="Camera.Text",Value="Cam1"). Using this in a script produces the error: BC30451: Name 'Value' is not declared. Is there a command to change headings using the API call in a script? If so, what is the command?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
There is definitely a bug but it's not vMix ;-) If formulated correctly like how it's mentioned in the helpfiles WILL let vMix recognize it
also no need to post the same thing twice
API.Function("SetText",Input:="some.gtzip",SelectedName:="Headline.Text",Value:="Some Text")
Joined: 10/24/2020(UTC) Posts: 25  Location: Virum Thanks: 10 times
Don't you miss a ":" after the "Value" - "Value:=" instead of "Value="
