Combining audio and video inputs
I know this can be done with multi view but my issue is the following:
I have two NDI inputs which are acting like webcams for a local stream. Each NDI has an audio input but I want to push the opposite audio to each. The guests are speaking to each other with the mics off of the NDI devices.
I’m using the 2 output option with vMix but since I’m using the preview as an output, I can’t use multi view to disable the audio when one is the main since both will be running simultaneously.
So basically, 2 NDI devices, two way audio, 2 output monitors and opposite audio pushed to each output.
Thoughts?? Thank you!!
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
 1 user thanked dmwkr for this useful post.
Thank you! Audio buses worked great. Took a little digging and learning but it's very powerful.
