marxentertainment
#1 Posted : Saturday, November 7, 2020 10:06:03 AM(UTC)
marxentertainment
I know this can be done with multi view but my issue is the following:
I have two NDI inputs which are acting like webcams for a local stream. Each NDI has an audio input but I want to push the opposite audio to each. The guests are speaking to each other with the mics off of the NDI devices.
I’m using the 2 output option with vMix but since I’m using the preview as an output, I can’t use multi view to disable the audio when one is the main since both will be running simultaneously.
So basically, 2 NDI devices, two way audio, 2 output monitors and opposite audio pushed to each output.
Thoughts?? Thank you!!
dmwkr
#2 Posted : Saturday, November 7, 2020 8:38:23 PM(UTC)
dmwkr
If I'm understanding you correctly you should use Audio Busses:
https://www.vmix.com/hel...OutputAudioChannels.html
https://www.vmix.com/help23/Mixer.html
Use Bus A for the first location, and route all audio inputs you want them to hear to Bus A, so eg. all inputs except their own. Same with B for the other location.
You could also take a look at Mix inputs, to send different video mixes to the locations.
https://www.vmix.com/help23/Mix.html
thanks 1 user thanked dmwkr for this useful post.
marxentertainment on 11/11/2020(UTC)
marxentertainment
#3 Posted : Wednesday, November 11, 2020 4:57:30 AM(UTC)
marxentertainment
Thank you! Audio buses worked great. Took a little digging and learning but it's very powerful.
