tikacademy
#1 Posted : Monday, November 9, 2020 12:03:04 PM(UTC)
tikacademy
Colombia
Hi all, my first post was a success, I solved my issue with a kinda-PITA solution, but a solution though.
Now I present you my scenario and question:
I have 12+ audio sources I don't know the word in English, but they're like short audio promos of my livestream and effects.
Currently I'm using all of them as INPUTS (a waste IMO) and I call them using shortcuts.
I want to know if I can use the PLAYLIST feature and assign keys to each promo and not having to add all of them and clutter the sources/input window
as I said I come from OBS where sources/inputs were unlimited and I just have the $60 version, I'm still on my 60-day trial though.
Any help or advise is greatly appreciated.
raugert
#2 Posted : Monday, November 9, 2020 12:15:22 PM(UTC)
raugert
Canada
Was thanked: 321 time(s) in 183 post(s)
You can put all your videos/audio sources into a "List". Then use the "SelectIndex" command in the shortcut key and enter the item line number in the "Value" field.
tikacademy
#3 Posted : Monday, November 9, 2020 2:05:29 PM(UTC)
tikacademy
Colombia
Thanks for your reply, this fora rules!, now I've changed D1 key for testing to selectIndex 1, it selects the item I can see that on the Playlist but it doesn't play it, so would I need to add anotehr key to actually play the input?, wouldn't that add more complexity or is there a way to select+play input?.
Regards.
Kelvin
#4 Posted : Monday, November 9, 2020 2:18:47 PM(UTC)
Kelvin
You have been a member since:: 2/9/2013(UTC)
Create another shortcut to "Play" using the same D1 key.
tikacademy
#5 Posted : Monday, November 9, 2020 2:26:02 PM(UTC)
tikacademy
Colombia
Created the entry as suggested, both shortcuts become red and doesn't work, what am I missing here?.
Cheers
raugert
#6 Posted : Monday, November 9, 2020 2:33:59 PM(UTC)
raugert
Canada
Yes you can add separate button to play the selected item. That's probably what most folks do.
If you want to select and play the item, you could also create a "Play" shortcut and add it to each key that selects the item. This is done by selecting the "Advanced" tab when you create the shortcuts and add the additional "Play" shortcut key.
If you want to select, play and cut direct to the item, you could also add the "Cut Direct" shortcut to each key.
Yes, flexibility breeds complexity :)
thanks 1 user thanked raugert for this useful post.
tikacademy on 11/10/2020(UTC)
tikacademy
#7 Posted : Wednesday, November 11, 2020 7:03:26 AM(UTC)
tikacademy
Colombia
Hey there, thanks again for your reply, I did as suggested, works great but how do i control that whenever a vidoe on the playlists ends it transitions back to another input, say my talking head cam?.
Sources stop fine but it stays on black and nothing happens, I'm thinking of a trigger but how do you add triggsrs to specific playlist items?.
Many thanks I'm on a roll here and getting set for my second vMix livestream tomorrow.
Cheers
Guest (4)
