Feature Requests
vMix Call - Allow send an input as return video to callers and not just outputs
Joined: 8/22/2020(UTC) Posts: 4  Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
The core problem is only having 4 outputs on vMix (not enough). For our workflow allowing to send an input to vmix callers would free up 1 to 2 outputs.
Part of the reason we burn through outputs is using an output to do an ISO record of a caller due to the fact that recording callers in the MultiCorder does not work well as it creates many different files for a single record session.
 1 user thanked DT_HRE for this useful post.
Joined: 9/4/2020(UTC) Posts: 22  Was thanked: 1 time(s) in 1 post(s)
+1 Having the ability to choose an input as a return to a vMix caller would prove invaluable.
Joined: 10/24/2020(UTC) Posts: 3  Location: Georgia Thanks: 1 times
+1
Return video using a vmix output is really frustrating.
Most useful would be inputs directly to return video,low res or NDI feeds would be of great help. Even a static image as a return image would be helpful, to re-assure the caller that they're on the right call because None is not helpful for the caller even if there is audio.
Originally Posted by: JoshYahoo  to re-assure the caller that they're on the right call because None is not helpful for the caller even if there is audio. How did we ever survive landline phonecalls
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
+1
Quite a good idea.
- Tom
Joined: 2/23/2023(UTC) Posts: 81  Thanks: 26 times Was thanked: 20 time(s) in 6 post(s)
Feature Requests
