Joined: 12/20/2012(UTC) Posts: 81  Location: INDIA, TAMILNADU Thanks: 5 times Was thanked: 8 time(s) in 6 post(s)
Martin, FLV FILE loop play not accurate.Flv Alpha file ( list mode play via stringer ) not work alpha overlay. the same time add input with overlay work fine? watch this video : thanku
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
List does not support FLV files. They might play if you PC has a codec available, but it usually does not support alpha.
admin wrote:List does not support FLV files. They might play if you PC has a codec available, but it usually does not support alpha.
all codec installed my pc.
via add input support alpha very fine.
an list support flv files. but, list not support alpha only.
loop play not accuracy. loop play between black screen.
please watch my video again.
thanku
As I said, vMix does not support FLV in a List. It may work on your computer but it doesn't mean List supports it properly which is why you are seeing some problems.
Please use a different video format when using lists.
admin wrote:As I said, vMix does not support FLV in a List. It may work on your computer but it doesn't mean List supports it properly which is why you are seeing some problems.
forget list. recording this question: loop play not accuracy. loop play between black screen.
