amsudeen
#1 Posted : Wednesday, March 5, 2014 7:57:40 AM(UTC)
amsudeen
Was thanked: 8 time(s) in 6 post(s)
Martin,
FLV FILE loop play not accurate.Flv Alpha file ( list mode play via stringer ) not work alpha overlay.
the same time add input with overlay work fine?
watch this video :
thanku
#2 Posted : Wednesday, March 5, 2014 8:57:27 AM(UTC)
List does not support FLV files.
They might play if you PC has a codec available, but it usually does not support alpha.
amsudeen
#3 Posted : Wednesday, March 5, 2014 9:57:21 AM(UTC)
amsudeen
all codec installed my pc.
via add input support alpha very fine.
an list support flv files. but, list not support alpha only.
loop play not accuracy. loop play between black screen.
please watch my video again.
thanku
#4 Posted : Wednesday, March 5, 2014 10:08:34 AM(UTC)
As I said, vMix does not support FLV in a List.
It may work on your computer but it doesn't mean List supports it properly which is why you are seeing some problems.
Please use a different video format when using lists.
amsudeen
#5 Posted : Wednesday, March 5, 2014 11:56:40 AM(UTC)
amsudeen
forget list.
recording this question: loop play not accuracy. loop play between black screen.
