 Joined: 6/5/2020(UTC) Posts: 91  Location: JakartaThanks: 17 timesWas thanked: 5 time(s) in 3 post(s)
                Hi, Currently I'm having problem with my Camera Input as shown on following screenshot:   Screenshot 2020-11-02 105553.png (1,063kb) downloaded 3 time(s). It is glitching randomly, what could be possibly wrong? Thanks in advance. |
 Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, FranceThanks: 243 timesWas thanked: 796 time(s) in 590 post(s)
                Difficult to say unless you give us more specific info about your setup ! We cannot guess what equipments you're using or what you're doing ! |
                Originally Posted by: DWAM  Difficult to say unless you give us more specific info about your setup ! We cannot guess what equipments you're using or what you're doing ! I'm using:
 DataVideo PTC-150
DataVideo SE-1200MU (Multi-Cams Hub to vMix)
Magewell USB Capture SDI
Surface Pro 5 (vMix PC, Windows 10 Build 2004)
 This is happening when the Camera Input active 15 minutes on PROGRAM, no change were made from the vMix PC when this is happen. is that clear enough? Thanks in advance. |
 Thanks: 122 timesWas thanked: 123 time(s) in 115 post(s)
                Check you Power Options in Settings.  Use High Performance and then go to Advanced Settings.  Make sure to the USB selective suspend setting is on Disabled
 Additionally, when your budget may allow, consider a more powerful computer.  If your Surface 5 has a M3 CPU, that processor isn't very powerful.  Since you are using a DataVideo SE-1200MU hardware switcher, it would seem that your setup is not a mobile one.  Have you thought about using a desktop instead of a laptop?
                Originally Posted by: SportsNetUSA.net  Check you Power Options in Settings.  Use High Performance and then go to Advanced Settings.  Make sure to the USB selective suspend setting is on Disabled
 Hi SportsNetUSA.net, Thanks for your help, This is a cable issue, once we corrected the cable it is back to normal. |
