Removing Photo from Social Title Speech Bubble
Removing Photo from Social Title Speech Bubble |
We have not found a way to remove a selected photo - in one of the Social Title Speech Bubbles
- Maybe it is obvious .. but we seemed to have "missed it" ..
Thanks in advance ..
Do you mean actual removing after it has been displayed or no have them displayed selecting a social comment ?
Thanks Doggy ... [ and others for looking ! ] we mean from the actual interface to create it ... to remove the Vegas image in this case .. Hope the attachment helps .. [ see attachment ]  FORUM QUESTION .png (176kb) downloaded 0 time(s).- We did discover that if we export as a .csv file .. we could delete from that .. ... and then "re import it " but thinking there must be an easier way ... [ we hope ? ]
You mention a csv so implying you are not letting it be driven by vMix Social (where on can eliminate the link ot the title.)
if driven by a general data source do not link the photo to it
I don't believe that helps..
The experience is creating
In VMIX title editor ...
... once the choice of a photo has been made it appears there is no undoing...
... or changing your mind to a different photo
The CSV file came up because we exported the title editor
in an attempt to find a clunky way around changing the photo
Originally Posted by: RDI  ... once the choice of a photo has been made it appears there is no undoing...
Guess i completely misunderstood your original question , the above was much clearer You are basically answering your own question ... change your mind = select another photo :-) You want to have no photo shown (remove) , select a blank photo (could use a shortcut for that) If that's till not it ... refrase
Yes that's it .....
Maybe once the title is actually used....
. possibly at that point it might be easy to change will have to double-check on that
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
Hi RDI, what version of vmix do you have. Because if you never want a image, why not remove it with the title desiger? (Only works with the expensive versions of vMix)
Originally Posted by: Pepsi(~)  Hi RDI, what version of vmix do you have. Because if you never want a image, why not remove it with the title desiger? (Only works with the expensive versions of vMix) - One can always edit a GT-title, just not have animations with Lower licenses - The speech bubble titles are XAML titles - One can Edit the Title Mapping (blank it) in vMix Social itself
