RDI
#1 Posted : Friday, October 30, 2020 9:10:54 AM(UTC)
RDI
Removing Photo from Social Title Speech Bubble |
We have not found a way to remove a selected photo - in one of the Social Title Speech Bubbles
- Maybe it is obvious .. but we seemed to have "missed it" ..
Thanks in advance ..
#2 Posted : Friday, October 30, 2020 9:23:02 AM(UTC)
Do you mean actual removing after it has been displayed or no have them displayed selecting a social comment ?
RDI
#3 Posted : Friday, October 30, 2020 9:32:58 AM(UTC)
RDI
Thanks Doggy ... [ and others for looking ! ]
we mean from the actual interface to create it ...
to remove the Vegas image in this case ..
Hope the attachment helps ..
[ see attachment ] FORUM QUESTION .png (176kb) downloaded 0 time(s).
- We did discover that if we export as a .csv file ..
we could delete from that ..
... and then "re import it "
but thinking there must be an easier way ... [ we hope ? ]
#4 Posted : Friday, October 30, 2020 10:00:12 AM(UTC)
You mention a csv so implying you are not letting it be driven by vMix Social (where on can eliminate the link ot the title.)
if driven by a general data source do not link the photo to it
RDI
#5 Posted : Friday, October 30, 2020 10:16:39 AM(UTC)
RDI
I don't believe that helps..
The experience is creating
In VMIX title editor ...
... once the choice of a photo has been made it appears there is no undoing...
... or changing your mind to a different photo
The CSV file came up because we exported the title editor
in an attempt to find a clunky way around changing the photo
#6 Posted : Friday, October 30, 2020 10:45:59 AM(UTC)
Guess i completely misunderstood your original question , the above was much clearer
You are basically answering your own question ... change your mind = select another photo :-)
You want to have no photo shown (remove) , select a blank photo (could use a shortcut for that)
If that's till not it ... refrase
RDI
#7 Posted : Friday, October 30, 2020 12:08:09 PM(UTC)
RDI
Yes that's it .....
Maybe once the title is actually used....
. possibly at that point it might be easy to change will have to double-check on that
Pepsi(~)
#8 Posted : Friday, October 30, 2020 5:02:27 PM(UTC)
Pepsi(~)
Netherlands
Hi RDI, what version of vmix do you have.
Because if you never want a image, why not remove it with the title desiger? (Only works with the expensive versions of vMix)
#9 Posted : Friday, October 30, 2020 5:44:06 PM(UTC)
- One can always edit a GT-title, just not have animations with Lower licenses
- The speech bubble titles are XAML titles
- One can Edit the Title Mapping (blank it) in vMix Social itself
Guest (4)
