koinonia
#1 Posted : Friday, October 30, 2020 6:34:56 AM(UTC)
koinonia
I have been noticing that since several updates, I was losing performance in vMix. Old complex projects that were done with CPU less than 48% now took almost 80%.
Today I made some tests and found that with integrated Intel GPU I could run more simultâneos vídeos than with nVidia.
My laptop is Asus GL552VW with 960M.
I than made the same test with Dell with 1050TI and the performance was exatctly the same with nVidia and intel integrated GPU, no difference in performance. So I guess there is something wrong going on with vMix?
Vince Beck
#2 Posted : Friday, October 30, 2020 6:50:27 AM(UTC)
Vince Beck
Might be time for a clean Windows install.
Also, an SSD getting full could cause issues. And of course, computers get slower over time as software gets more complex.
koinonia
#3 Posted : Friday, October 30, 2020 8:02:40 AM(UTC)
koinonia
I made a clean Windows installation.
Tested in 2 machines.
I would like to know if anyone else is having the same problem.
By the way, anyone could make the same test to see if only I am having this problem.
Just change in the nvidia control panel the integrated GPU for vMix and check the performance.
rafafischerfoto
#4 Posted : Friday, October 30, 2020 2:59:33 PM(UTC)
rafafischerfoto
Brazil
Hi!
I've observing the same kind of inconsistency, I have tested a GTX1070 and a Radeon RX5700 XT where, officialy, the Radeon didn't have GPU encoding support on vMix, but the performance is far better with the latter...
My Topic: https://forums.vmix.com/...celerated-encoding-doubt
Em tempo, brasileiro aqui, e também, pelo visto de igreja :-)
koinonia
#5 Posted : Friday, October 30, 2020 10:55:14 PM(UTC)
koinonia
Originally Posted by: rafafischerfoto Go to Quoted Post
Hi!
That's exactly what I am talking about: dedicated GPU (as nVidia) should be far more powerfull than the integrated GPU. Maybe the vMix now is only optimized for nVidia RTX cards...
I will do a test with a machine with RTX2060.
(sim, somos irmãos em Cristo! Um, gde abs!)
mjgraves
#6 Posted : Friday, October 30, 2020 11:44:15 PM(UTC)
mjgraves
Perhaps roll back the video card driver and see if it changes anything.
koinonia
#7 Posted : Friday, October 30, 2020 11:48:37 PM(UTC)
koinonia
I did this before, No difference. I don't think it's a videocard driver issue.
MycroBeat99
#8 Posted : Saturday, October 31, 2020 12:08:49 AM(UTC)
MycroBeat99
Romania
Same issue on 2 machines with GTX 1070 and GTX 1060 (Desktop variants).
Sometimes when i load a video more then 1 hour, the GPU memory increases by almost half (sometimes a 30 minutes video as well). Another issue is sometimes the SRT use CPU decoding insead of GPU decoding, even if i select the GPU decoding in menu or i have a performant GPU.
vMix is now optimized for new hardware (from my point of view, this is not an optimization), but is sad because not all from here we have thousands of euros/dollars (A new computer in Eastern Europe, for exemple, is about 1500 to 2000 euro, which is 4 time more than minimum salary) to spend on new hardware.
rafafischerfoto
#9 Posted : Saturday, October 31, 2020 9:43:31 AM(UTC)
rafafischerfoto
Brazil
Hi!
Maranata Irmão!
I don´t have any RTX to test, just the GTX1070 and the RX5700 XT. I think that this may be related to the maximum number of video streams that NVENC can handle in non-Quadro (1 or 2, depending on the model/generation), so, I can´t find any information about the number of paralel encoding tasks on the Navi cards (Radeon 5000 series). If this is true, vMix is using more hardware streans on AMD/Intel setups than in nVidia...
MycroBeat99
#10 Posted : Saturday, October 31, 2020 10:56:32 AM(UTC)
MycroBeat99
Romania
The Nvidia NVENC restriction is not applied to my. I have a modified GPU card that can carry more than 2 NVENC and is transformed into a Quadro, so the problem is on vMix.
Why Adobe products do without any problem more then 10 video render using NVENC, and vMix block, crash or maybe use CPU instead of GPU?!! We speak with no purpose, the vMix developer it hurts at the banana about our problems and out "old" hardware.
dmwkr
#11 Posted : Saturday, October 31, 2020 6:06:13 PM(UTC)
dmwkr
I don't think one "just" has to change one setting. At least you would have to connect your monitor to the output of the other GPU, as it is not advisable to use multiple GPUs with vMix, afaik. Where do you have your monitor connected?
rafafischerfoto
#12 Posted : Sunday, November 1, 2020 3:20:22 AM(UTC)
rafafischerfoto
Brazil
I haven't idea that the NVENC limitations on GeForce cards are software-inflicted :-(
About my tests, I've made some experiments here: https://forums.vmix.com/...celerated-encoding-doubt
