Joined: 11/12/2012(UTC) Posts: 58  Location: Tarnów, Poland Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
still little bugs :)
1. Audio from MXF isn't displayed in audio meters
2. Adding second video delay to a capture input (which isn't supported by vMix and it throws an exception) breaks previously added Video Delay - it stops recording :(
edit: vMix 12 has bigger CPU usage than v11 - in vMix11 playing 3 MP4 720p50 streams + recording to MPEG-2 720p50 50Mbps + streaming in OBS with IntelQuickSync causes max. 25% of CPU usage, while v12 has peaks up to 50% and constantly drops frames from recording and input previews are stuttering
my system specs: Intel Core i7 2600k P8Z68V/Gen3 16GB RAM DDR3 1333Mhz GF GTX 550 Ti (in x16 slot but runs at x8 speed because of Decklink Quad in x8 slot) Decklink Quad Decklink Duo (x4 slot) Windows 8.1 Pro x64
Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
Originally Posted by: Ernest Kró  dundurs wrote:Looking great. Any chance, however, to get 960x540 added to the list of resolution? FMLE resize is a CPU killer.
Thanks, Dundurs Consider using Open Broadcaster Software https://obsproject.com/ - it has very fast implementation of x.264 and you can adjust many compression parameters :) Yes, we have tried it, but there are also some issues.
i've found that frame drops occurs mostly while one of the external outputs has disabled one of the overlay channels i.e.
External 1 overlay channel 4 disabled, no virtual device, no external decklink renderer, only for recording
External 2 all overlay channels enabled, virtual device, no external decklink renderer
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Hi Ernest,
Is the CPU usage the same when just running one external output? Keep in mind a second external output requires another full output render of vMix so you will need a graphics card that can support this. If the render time is above 20ms with it enabled, then a faster graphics card is required.
Martin vMix
A new vMix 12 Preview is now available. (12.0.0.109)http://www.vmix.com.au/download/vmix12preview.exeThis will likely be posted to the web site in a week as the release version, so if you have any last minute bugs to report, please do so now! Changes/Fixes* FIX: DVD Previous Chapter button was not working correctly * FIX: Recording filename dialog was showing wrong type * FIX: MXF was not showing correct audio levels Regards, Martin vMix
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Martin , if this is the Release candidate what happened to Quote:"There are also two major new features in the works which will not be revealed until shortly before NAB 2014!" admin wrote:A new vMix 12 Preview is now available. (12.0.0.109)http://www.vmix.com.au/download/vmix12preview.exeThis will likely be posted to the web site in a week as the release version, so if you have any last minute bugs to report, please do so now! Changes/Fixes* FIX: DVD Previous Chapter button was not working correctly * FIX: Recording filename dialog was showing wrong type * FIX: MXF was not showing correct audio levels Regards, Martin vMix
 1 user thanked Henny for this useful post.
Joined: 11/14/2012(UTC) Posts: 414  Location: Finland Thanks: 272 times Was thanked: 40 time(s) in 38 post(s)
Henny wrote:Martin , if this is the Release candidate what happened to Quote:"There are also two major new features in the works which will not be revealed until shortly before NAB 2014!" I have also wondered this lately. Kind regards, J. Tervo
The two new features are ready, but won't be "switched on" until shortly before NAB!
admin wrote:The two new features are ready, but won't be "switched on" until shortly before NAB! Nice :) Have not tested yet the latest build, but has this been fixed: "Virtual set should remember its transition duration, now its always go back to 4 sec after reloading." Kind regards, J. Tervo
Joined: 5/11/2012(UTC) Posts: 23  Location: Norway Thanks: 2 times Was thanked: 6 time(s) in 2 post(s)
Hi Martin,
While playing with your latest version I noticed something... ;-)
I cant enable the second Virtual video (vMix Video External 2) I can check the checkbox in Settings - External Outputs - External 2 (vMix Video device), but it does not give an output when clicking External "start" (not even after program restart). The first Virtual video (just called vMix Video) works OK. Is it because I don't have a third monitor connected, or just me doing something stupid again? (Or do I need a better license?)
I don't plan to use this feature but it would be nice to know that it works. This also confuse "Livestream for Producers" which defaults to the second (vMix Video External 2) and don't want to stay with the first (vMix Video), but this "vMix Video External 2" have the same output as the First video output so I can stream OK :-)
I will also post some feature requests in a minute.
Best regards KKR
Strange, if you can see the video from vMix Video External 2 then it means the output is working. What license are you using? Only Trial and HD Pro have access to it.
A new vMix 12 Preview is now available. (12.0.0.110)http://www.vmix.com.au/download/vmix12preview.exeThis will likely be posted to the web site in a week as the release version, so if you have any last minute bugs to report, please do so now! Changes/Fixes* FIX: Fix for vMix Video External 2 with Livestream Producer Regards, Martin vMix
jet wrote: "Virtual set should remember its transition duration, now its always go back to 4 sec after reloading."
This will have to wait for a future release unfortunately, major bugs are the priority as we get close to the final version.
Hey, I wasn't sure if this was intended or not... but when you set an input as an overlay, any triggers attached to that input don't actually trigger. They work fine when you transition to the input via a mix or fade or something but when you try to set it as an overlay they don't trigger.
Killerhands wrote:Hey, I wasn't sure if this was intended or not... but when you set an input as an overlay, any triggers attached to that input don't actually trigger. They work fine when you transition to the input via a mix or fade or something but when you try to set it as an overlay they don't trigger. Yes that is intentional, triggers will only work for the master input, not for overlays. The reason for this is to prevent complicated setups that may end up putting vMix in a loop.
Joined: 11/30/2013(UTC) Posts: 165 Location: Seoul, South Korea
Thanks: 39 times Was thanked: 19 time(s) in 14 post(s)
Regarding the new video delay feature in vMix 12... can you please enable the audio delay slider in the Audio Settings dialog to delay >2,000 milliseconds of audio? The feature to delay audio is already implemented, but the ability to delay up to 15,000msec (15 seconds) would be really desirable.
Thank you Martin!
