lem120
#1 Posted : Wednesday, October 28, 2020 4:09:54 AM(UTC)
lem120
Italy
I have to set a chimes on 1 minute left from a countdown, but this input doesn't come out to the program but only in an output3 in NDI in another software.
Is there a way to delay the chimes play until 14 minutes or just delay?
Thank you so much
#2 Posted : Wednesday, October 28, 2020 4:27:27 AM(UTC)
You have been a member since:: 12/27/2012(UTC)
Do i understand correctly ? from a NDI feed from somewhere else?
That will be a very hard thing to achieve. I like trying to interpret a clock from video footage
Dont you have a way to run a countdown on your main machine ?
lem120
#3 Posted : Wednesday, October 28, 2020 7:43:44 AM(UTC)
lem120
Italy
No no no,
I assume my English is not so good...
The countdown input goes from vMix to the output3 that in NDI goes to another software.
#4 Posted : Wednesday, October 28, 2020 8:36:00 AM(UTC)
Originally Posted by: lem120 Go to Quoted Post
No no no,
ok understood
if you have scripting option in your license , than let the script check the time and act upon that , there are examples in scripting for dummies thread that respond with color but that's the same principle
lem120 on 10/28/2020(UTC)
lem120
#5 Posted : Wednesday, October 28, 2020 8:37:49 AM(UTC)
lem120
Italy
ok,
I'll check for this.
Thank you so much Doggy
lem120
#6 Posted : Wednesday, October 28, 2020 8:40:09 AM(UTC)
lem120
Italy
If you have some quick example I will appreciate.
#7 Posted : Wednesday, October 28, 2020 8:42:17 AM(UTC)
so you went through the "scripting for dummies" thread in 2 minutes ?
