Hi, I have to set a chimes on 1 minute left from a countdown, but this input doesn't come out to the program but only in an output3 in NDI in another software. Is there a way to delay the chimes play until 14 minutes or just delay?
Thank you so much
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Do i understand correctly ? from a NDI feed from somewhere else?
That will be a very hard thing to achieve. I like trying to interpret a clock from video footage
Dont you have a way to run a countdown on your main machine ?
No no no, I assume my English is not so good... The countdown input goes from vMix to the output3 that in NDI goes to another software.
Originally Posted by: lem120  No no no, I assume my English is not so good... The countdown input goes from vMix to the output3 that in NDI goes to another software. ok understood if you have scripting option in your license , than let the script check the time and act upon that , there are examples in scripting for dummies thread that respond with color but that's the same principle
ok, I'll check for this.
Thank you so much Doggy
If you have some quick example I will appreciate.
Originally Posted by: lem120  If you have some quick example I will appreciate. so you went through the "scripting for dummies" thread in 2 minutes ?
