Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Hi, Does currently vMix supports to fade audio in and out inside Triggers? For example if I have Image Input, when I CUT that input, I want to fade the Music automatically for around 500ms.  Annotation 2020-06-05 161226.jpg (43kb) downloaded 5 time(s).Thanks a lot. Best Regards, Henoch
Originally Posted by: stigaard  Hi Stigaard, Thanks for your explanation, I tried below:  Annotation 2020-06-05 195442.jpg (45kb) downloaded 9 time(s).But I got below error:  Annotation 2020-06-05 195607.jpg (19kb) downloaded 6 time(s).Please be kindly advise.
as indicated in grey, the Value field expects 2 values. It makes sense that a duration is mandatory as you precisely don't want to make a CUT
Originally Posted by: DWAM  as indicated in grey, the Value field expects 2 values. It makes sense that a duration is mandatory as you precisely don't want to make a CUT Hi Dwam, Thanks for your explanation, I missed that I need to fill the value with formatted value (Volume,Duration = 100,1000). All Good Now.
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
