gpdipalmerahtimur
#1 Posted : Friday, June 5, 2020 7:06:46 PM(UTC)
gpdipalmerahtimur
Indonesia
Does currently vMix supports to fade audio in and out inside Triggers? For example if I have Image Input, when I CUT that input, I want to fade the Music automatically for around 500ms.
Annotation 2020-06-05 161226.jpg (43kb) downloaded 5 time(s).
Thanks a lot.
Best Regards,
Henoch
stigaard
#2 Posted : Friday, June 5, 2020 7:26:32 PM(UTC)
stigaard
Denmark
Yep.
See shortcut list https://www.vmix.com/hel...utFunctionReference.html
Especially SetVolumeFade
gpdipalmerahtimur
#3 Posted : Friday, June 5, 2020 10:55:25 PM(UTC)
gpdipalmerahtimur
Indonesia
Originally Posted by: stigaard Go to Quoted Post
Yep.
Hi Stigaard,
Thanks for your explanation, I tried below:
Annotation 2020-06-05 195442.jpg (45kb) downloaded 9 time(s).
But I got below error:
Annotation 2020-06-05 195607.jpg (19kb) downloaded 6 time(s).
Please be kindly advise.
#4 Posted : Friday, June 5, 2020 11:01:11 PM(UTC)
as indicated in grey, the Value field expects 2 values. It makes sense that a duration is mandatory as you precisely don't want to make a CUT
gpdipalmerahtimur on 6/6/2020(UTC)
gpdipalmerahtimur
#5 Posted : Saturday, June 6, 2020 2:24:21 PM(UTC)
gpdipalmerahtimur
Indonesia
Hi Dwam,
Thanks for your explanation, I missed that I need to fill the value with formatted value (Volume,Duration = 100,1000). All Good Now.
Gunnar
#6 Posted : Wednesday, October 28, 2020 5:07:50 AM(UTC)
Gunnar
Sweden
