I purchased a Basic HD license of VMIX thinking that while I would not be able to 'play' motion graphics/titles in VMIX, I would be able to create them with GT Title Designer.
Well, I found out the hard way that this is not the case.... I don't really want to be forking out over AUD$1700 for the HD version, so I can just create titles. Is there a standalone version of GT Title Designer WITH motion capabilities that I can purchase?
Thanks and regards
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thanks and regards you can 'play' motion graphics/titles, those that come with your install, and you can create your titles , just not with animations. Also there is still the xaml legacy titles which you can create with animations AUD$1700 for the HD version ?? where did you find that? That's a huge jump for a one level up from you $60 license
Thanks and regards you can 'play' motion graphics/titles, those that come with your install, and you can create your titles , just not with animations. Also there is still the xaml legacy titles which you can create with animations AUD$1700 for the HD version ?? where did you find that? That's a huge jump for a one level up from you $60 license Apologies, I meant to say PRO version...My understanding is that to create motion graphics (in the new form) you must have either the 4K or PRO version. The HD version is AUD$549 (but with no motion using GTD) while Pro is AUD$1799. What differences are there in creation and playing of motion titles when using xaml and non xaml?
Thanks: 1 times Was thanked: 6 time(s) in 6 post(s)
 1 user thanked Ramón for this useful post.
GT is GPU accelerated and support animations in the 4K and Pro editions of vMix. (xaml is CPU) to create titles in xaml:
 1 user thanked elvis55 for this useful post.
