Animatic
#1 Posted : Tuesday, June 2, 2020 9:30:56 AM(UTC)
Animatic
So if I build a set of inputs and save them as a preset named "Show-001".
Then I build a new set of inputs and save them as a preset named "Show-002".
So now preset "Show-002" is the current preset that is open.
Now say I want to add a few of the input from "Show-001" to the current preset that is open "Show-002".
So I select OPEN the select preset "Show-001"
I select from the list of the inputs in "Show-001" and choose APPEND.
All good so far.
The problem is now that I have "Show-002" setup just the way I want it,
if I now save the preset it defaults to the appended preset name which is "Show-001"
which then obviously over writes my existing "Show-001".
My suggestion is:
If you APPEND to an open preset it keeps the original open set name.
If you OPEN a preset it then obviously uses the preset you opened as the name to save as.
For example:
If open preset "Show-001" then APPEND a few input from preset "Show-002"
The save as name should stay "Show-001"
Make sense?
AlanZ
#2 Posted : Monday, August 31, 2020 9:29:57 AM(UTC)
AlanZ
I was just about to make a similar post. Appending Inputs from another preset renames the current preset to that of the one supplying the inputs... in my opinion this should not happen.
Gunnar
#3 Posted : Monday, October 26, 2020 6:28:57 AM(UTC)
Gunnar
Sweden
+1
I have also problem with this. Always have to rename to the old name.
Very easy to do wrong with it as it is now.
