vMix Call
Since 10/19 unable to connect to VMixCall session
We have a meeting every Monday that we use a vmix call session to address the company remotely. This past Monday the session will connect but no video or audio. I've tried now from a few different computers/locations. No settings have changed on the server side wondering if there is something that has changed with VMixCall perhaps? Version 21.0.0.61 x64
Joined: 4/23/2017(UTC) Posts: 1,493  Location: Germany Thanks: 3 times Was thanked: 198 time(s) in 178 post(s)
beta.vmixcall.com has changed to advanced.vmixcall.com Apart from that vmixcall should be the same. Try to force P2P connection. In that case the vmixcall server is just used to establish the communication in the beginning. Once connected it's solely due to the two sides, no vmixcall servers in the chain then.
Thanks Mavik, I will give that a try!
Originally Posted by: mavik  beta.vmixcall.com has changed to advanced.vmixcall.com Apart from that vmixcall should be the same. Try to force P2P connection. In that case the vmixcall server is just used to establish the communication in the beginning. Once connected it's solely due to the two sides, no vmixcall servers in the chain then. Still no luck. Working with SDWan provider to see if anything was updated in our WAN firewall policies that would prevent audio and video from transmitting. Strange, the title updates so I know the connection is happening just no video or audio as of Monday (10/19).
vMix Call
