Hardware Compatibility
Atem Mini Pro ISO stream direct to vmix?
Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
Maybe a silly question... but is it possible to stream direct rtmp stream (ethernet) output from Atem Mini Pro ISO to Vmix?
I need to record all 4 cameras + program thru usb-c (for later edit and 4k relink) and use the hdmi for multiview out, BUT I need to send the program output to vmix for live streaming and vmixcall purposes.
Maybe I need a bigger switcher...
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 794 time(s) in 589 post(s)
Quote: is it possible to stream direct rtmp stream (ethernet) output from Atem Mini Pro ISO to Vmix? No Quote:I need to send the program output to vmix for live streaming and vmixcall purposes Just connect the Atem to the vMix computer with the USB-C cable. vMix will then "see" the Atem as a capture card.
Originally Posted by: DWAM  Just connect the Atem to the vMix computer with the USB-C cable. vMix will then "see" the Atem as a capture card.
USB-C is busy recording on ssd disk 4 camares + program. Thank you!
Originally Posted by: lainol  Originally Posted by: DWAM  Just connect the Atem to the vMix computer with the USB-C cable. vMix will then "see" the Atem as a capture card.
USB-C is busy recording on ssd disk 4 camares + program. Thank you! Did you solve this? I have the same doubt.
Originally Posted by: AlbertoBCN  Did you solve this? I have the same doubt.
1. download and run Monatiny, tuto below: https://www.reddit.com/r..._a_local_rtmp_server_so/2. make a custom rtmp for the atem mini, google that, lot of tutorials, put your pc ip address, remember to restart atem software control 3. vmix: new input - stream/srt - VLC (prompted to install vlc for vmix, do it): rtmp://your_local_ip/abc/xyz (as Monatiny tutorial example) It has +- 3 seg delay
