lainol
#1 Posted : Monday, October 19, 2020 8:16:13 PM(UTC)
lainol
Maybe a silly question... but is it possible to stream direct rtmp stream (ethernet) output from Atem Mini Pro ISO to Vmix?
I need to record all 4 cameras + program thru usb-c (for later edit and 4k relink) and use the hdmi for multiview out, BUT I need to send the program output to vmix for live streaming and vmixcall purposes.
Maybe I need a bigger switcher...
#2 Posted : Monday, October 19, 2020 11:29:36 PM(UTC)
Was thanked: 794 time(s) in 589 post(s)
No
Just connect the Atem to the vMix computer with the USB-C cable. vMix will then "see" the Atem as a capture card.
lainol
#3 Posted : Tuesday, October 20, 2020 9:50:48 PM(UTC)
lainol
USB-C is busy recording on ssd disk 4 camares + program.
Thank you!
AlbertoBCN
#4 Posted : Sunday, December 26, 2021 12:13:59 AM(UTC)
AlbertoBCN
Thank you!
Did you solve this? I have the same doubt.
lainol
#5 Posted : Monday, December 27, 2021 11:34:11 AM(UTC)
lainol
1. download and run Monatiny, tuto below:
https://www.reddit.com/r..._a_local_rtmp_server_so/
2. make a custom rtmp for the atem mini, google that, lot of tutorials, put your pc ip address, remember to restart atem software control
3. vmix: new input - stream/srt - VLC (prompted to install vlc for vmix, do it): rtmp://your_local_ip/abc/xyz (as Monatiny tutorial example)
It has +- 3 seg delay
