Joined: 11/14/2012(UTC) Posts: 364  Location: Finland Thanks: 234 times Was thanked: 24 time(s) in 22 post(s)
admin wrote:A new vMix 12 Preview is now available. (12.0.0.98)http://www.vmix.com.au/download/vmix12preview.exeChanges/Fixes* NEW: Second External Output / Virtual Capture device ("vMix Video External 2") available in HD Pro. * NEW: Triggers now support a delay * FIX: Crash when playing multiple quicktime H264 videos in x64 * FIX: Flash mouse drag/drop was not working correctly * FIX: Video Delay flicker issue under heavy load when delaying the main output * FIX: Various fixes to Shortcut auto input mapping functionality * FIX: Various performance and reliability improvements to web interface * FIX: Under consistent heavy load, Stream input may not be able to reduce buffer fast enough. In these situations the buffer is cleared and playback restarted. Regards, Martin vMix Hi Martin! There is an issue with the black border on Preview and Output (on top, bottom, left and right). It won't affect the final output, but its very annoying because its's giving the impression that the video frame have been scaled down and not filling the entire screen. The issue goes away if I narrow vMix window manually then its displaying them right (balck bordes only on top and bottom on 16:9 sources). I assume it only happens with some systems that have 'odd' screen resolutions. It works OK on my desktop machine but not on my laptop. This issue is also happening with v11. Kind regards, J. Tervo
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
The black border is just part of the vMix interface window. It will grow and shrink according to the size of the desktop and vMix will automatically place the video in the center at the maximum possible size.
Martin vMix
admin wrote:Hi,
Martin vMix Hi! OK. Then it would be essential to be able to change the gray background to black or disable completely the black box containing the Preview and Output (or be able to change its color to the same as background gray). One and best solution would be user configurable narrow borders on the actual outlines of the Preview and Output. Kind regards, J. Tervo
Me gustan las nuevas características, pero he venido enviando desde hace poco una traducción en español fiable pero no se ha añadido, pues la traducción al español que posee la actual vMix es muy pobre y confuza, si aceptaran mi aporte todo sería diferente. Además pienso que deberian de darnos la oportunidad a quienes tenemos más de un año de haber adquirido vMix, para poder comprar una actualización y no una licencia completa. Por otro lado el trabajo esta múy bueno.
Quedo a sus ordenes para poder aportar la traducción a Español Latino y así mismo solicito se añadan más categorías, y la posibilidad de editar una Playlist que este en curso.
Joined: 12/2/2011(UTC) Posts: 77 Location: Europe / The Netherlands
Hi Martin, admin wrote:
Notes
SetMultiViewOverlay takes a Value in the format 3,5 where 3 = the Overlay number to change and 5 = the input to use as the overlay. For example, this shortcut can be used to switch an input when using a double box effect.
Martin vMix
Thanks! One question left, what if I want to the set an overlay to 'None'? I expect something like 3,0 (or 3,-1). But without effect. How does it work? Regards, Hanno.
Tengo poco menos de dos años de utilizar vMix
Lamentablemente la traducción al español latino de este programa, más que erronea, es deficiente.
Me he tomado la libertad de colaborar con vuestra traducción al español de una manera correcta en un 95%, ya que la traducción que posee vMix12Preview es correcta en un 20%
Espero que no ignoren este aporte tal y como se ha hecho en las anteriores ocasiones. Esta es una colaboración acertada ya que Google Translator no realizó la traducción como realmente es, y esto ocasiona confusión a quienes utilizan vMix en paises de habla hispana. Ya he enviado una copia del fichero a vuestro Buzón email
ber142 wrote: Thanks!
Regards, Hanno.
Set the second number to an input that doesn't exist, such as 1000 to set it to None.
A new vMix 12 Preview is now available. (12.0.0.105)http://www.vmix.com.au/download/vmix12preview.exeThis will likely be posted to the web site in a week as the release version, so if you have any last minute bugs to report, please do so now! Changes/Fixes* NEW: Preview/Output will resize as needed instead of adding black borders * NEW: When an overlay is being previewed in the Preview window and a transition occurs, that overlay will be activated also. * FIX: Fixed MarkIn/MarkOut not working with MOV files in List. * FIX: Certain characters were not showing correctly in the web title interface. * FIX: Auto restart was causing MOV files to begin playing again * FIX: Fixed MultiCorder issues when adding/removing capture inputs. Regards, Martin vMix
Quote:NEW: Preview/Output will resize as needed instead of adding black borders What a difference !!! +100
admin wrote:A new vMix 12 Preview is now available. (12.0.0.105)http://www.vmix.com.au/download/vmix12preview.exeThis will likely be posted to the web site in a week as the release version, so if you have any last minute bugs to report, please do so now! Changes/Fixes* NEW: Preview/Output will resize as needed instead of adding black borders * NEW: When an overlay is being previewed in the Preview window and a transition occurs, that overlay will be activated also. * FIX: Fixed MarkIn/MarkOut not working with MOV files in List. * FIX: Certain characters were not showing correctly in the web title interface. * FIX: Auto restart was causing MOV files to begin playing again * FIX: Fixed MultiCorder issues when adding/removing capture inputs. Regards, Martin vMix I need to be implemented: listen to the preview, it could be set to output audio added. It is also necessary to add the function that allows modify without stopping Playlist. Start with full screen, does not work on Windows 7 64.
Joined: 2/26/2014(UTC) Posts: 83  Location: Canada Thanks: 18 times Was thanked: 16 time(s) in 16 post(s)
Hi what are requirements to get Hardware Acceleration to MP4 Recording, i try but no cpu difference,i have GTX 660 2 GB Thanks! admin wrote:The final vMix 12 Preview (12.0.0.86) is available for download below: http://www.vmix.com.au/download/vmix12preview.exeOnly bug fixes should now be reported for vMix 12, all feature requests should go into the Feature Requests forum for vMix 13. Changes/Fixes* CHANGED: New render engine for Stream Input. Smoother video with better buffer management. * ADD: New shortcut functions: SetMultiViewOverlay, SetZoom, SetPanX, SetPanY * ADD: Hardware Acceleration tickbox added to MP4 Recording tab.Will use Intel hardware acceleration where available * ADD: MultiCorder supports recording to MPEG-2 Transport Stream. This can be used for recording multiple HD cameras to a standard hard drive as long as there is enough CPU power available. * ADD: Japanese language support through Google Translate * FIX: Audio Mixer updates when using SetVolume in API * FIX: Fixed video only MOV files paying too fast in x64 * FIX: Fixed various bugs where a language region uses commas instead of decimal points. * FIX: Fixed two bugs in how clipping was handled with MultiView * FIX: Fixed out of bounds bug with trackbar NotesSetMultiViewOverlay takes a Value in the format 3,5 where 3 = the Overlay number to change and 5 = the input to use as the overlay. For example, this shortcut can be used to switch an input when using a double box effect. Regards, Martin vMix
Thanks Martin!! Yes, I know new feature requests should be posted else, but would like to have some indicator to v12 which would show the currently selected/active Virtual set picture size (and when the transition is still going it should blink / change color). Virtual set should remember its transition duration, now its always go back to 4 sec after reloading. Kind regards, J. Tervo
Joined: 11/12/2012(UTC) Posts: 58  Location: Tarnów, Poland Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
MXF/MOV file playback issues: audio from these files is played by the system default audio interface instead of the chosen one in the settings.
A new vMix 12 Preview is now available. (12.0.0.107)http://www.vmix.com.au/download/vmix12preview.exeThis will likely be posted to the web site in a week as the release version, so if you have any last minute bugs to report, please do so now! Changes/Fixes* FIX: MOV/MXF were not using the selected audio renderer * FIX: Fixed PID issue with some transport streams * FIX: CPU utilisation issues when playing back many RTSP streams. Regards, Martin vMix
Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
admin wrote:A new vMix 12 Preview is now available. (12.0.0.107)http://www.vmix.com.au/download/vmix12preview.exeThis will likely be posted to the web site in a week as the release version, so if you have any last minute bugs to report, please do so now! Changes/Fixes* FIX: MOV/MXF were not using the selected audio renderer * FIX: Fixed PID issue with some transport streams * FIX: CPU utilisation issues when playing back many RTSP streams. Regards, Martin vMix Looking great. Any chance, however, to get 960x540 added to the list of resolution? FMLE resize is a CPU killer. Thanks, Dundurs
dundurs wrote:Looking great. Any chance, however, to get 960x540 added to the list of resolution? FMLE resize is a CPU killer.
Thanks, Dundurs Consider using Open Broadcaster Software https://obsproject.com/ - it has very fast implementation of x.264 and you can adjust many compression parameters :)
Joined: 1/25/2012(UTC) Posts: 17 Location: Berwick, PA
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Any chance we can get more overlay inputs? Right now there are 4, but there have been times when I could have used 6 or 7. Love vMix from the get-go and will be upgrading to v12! -Doug
Joined: 6/29/2011(UTC) Posts: 314   Location: Florida Thanks: 6 times Was thanked: 34 time(s) in 33 post(s)
Doug wrote:Any chance we can get more overlay inputs? Right now there are 4, but there have been times when I could have used 6 or 7. Love vMix from the get-go and will be upgrading to v12! -Doug @Doug Don't know if you know this or not but you can combine overlay graphics with the multiview feature.
Joined: 11/21/2013(UTC) Posts: 32 Location: Stockholm
Thanks: 2 times Was thanked: 5 time(s) in 5 post(s)
Maybe this is an old bug. There is a bug when setting up recording and you click on mp4 and choose browse to choose location and filename the extension says avi. However the recording will be a .mp4 but the name will be test.avi-date-time.mp4. If you click on mp4 after you've chosen location and name the filename will be test-date-time.mp4
 1 user thanked tubbis_2 for this useful post.
tubbis_2 wrote:Maybe this is an old bug. There is a bug when setting up recording and you click on mp4 and choose browse to choose location and filename the extension says avi. However the recording will be a .mp4 but the name will be test.avi-date-time.mp4. If you click on mp4 after you've chosen location and name the filename will be test-date-time.mp4 Thanks bringing this up. Yes, I have run in to this bug also, but didn't yet report it. Kind regards, J. Tervo
Video mixed with vMix (studio portions). Turn subtitles / CC on:
