Hello
why are we still in the world of deley in the world of vMIX?
it says and claims to be THE proffesional preference of choice for streaming ?
it kind of feels like in the beginning you remember the days of before zero latency being the goal for any proffesional user norm.
with the constant updates aiming for the next hip and colors shuffling around the dash to bring a new look it would be nice to see the developers kind of adress the more basic feautures of bringing the ears and lips together in a big smile.
vMIX is not a proffesional choise it is just not there but nice try.
regards clas sjostrand
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Point us to a streaming "software" solution that doesn't have significant delay. Wirecast? Tricaster? OBS? Xsplit? Nope. They all do because they are software based, the delay is a reult of the platform.
If you want very little delay and similar features, look at Ross, Barco, etc. Of cource also add a couple of zeros and some hair loss treatment to the bill :-)
BTW, delay is also linked to hardware. We just built 2 Obsidian systems and the delay is minimal.
Joined: 10/22/2020(UTC) Posts: 2  Location: Stockholm
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
As has already been pointed out at length, the latency set is by design and necessary as audio drops occur otherwise and audio won't be in sync with video.
In the old days for a home production you had to take out your 8mm film camera ( 16mm if you had more cash) shoot your stuff and wait for the film to com back developed. Then to edit you had the physically cut the filmstrips , grind the end and weld (glue) the pieces together in a proper order and throw away the bad stuff ( or reshoot) Same thing with audio recordings on tape , then mark (with a marker or bit of colored tape) a start point on it to sync with a frame to start from. The most important editing tool for a nice production was the cutter or scissors ;-) To show your production you had to put your first frame on the right spot in the projector , loop the audio tape from the player through your projector so both would loop through at the same speed , match it with your tape marking and keeps your fingers crossed the tape didn't slip and got out of sync or even worse a weld in the filmstrip didn't break due to the heat of the lamp And we fuzz about a ms ;-) ?t=68
 2 users thanked doggy for this useful post.
elvis55 on 10/23/2020(UTC), ask on 10/23/2020(UTC)
