xbamaris
#1 Posted : Saturday, October 17, 2020 4:35:51 AM(UTC)
xbamaris
I was wondering if there was a way or of it could be added for the Multiview layout to have a Record/Stream indicator some where. As in, if vMix is recording/streaming. It shows that it is.
If this is already possible please show me how! Thanks!
migrif
#2 Posted : Saturday, October 17, 2020 7:46:42 PM(UTC)
migrif
New Zealand
You can do this already. Only for either Record or Stream, not both from what I can see.
Go into the settings > Options > Transition Display: Enable Production Clocks.
Double click on the production clock below the T Bar, then choose either a streaming or recording type, click create input.
You can now add this to your multiviewer.
Hope this helps
thanks 1 user thanked migrif for this useful post.
tom0101 on 3/23/2021(UTC)
