manuelbotto
#1 Posted : Friday, October 16, 2020 3:38:12 AM(UTC)
manuelbotto
Italy
shortcuts nextitem and previusitem, is it possible to somehow make it active for multiple lists?
#2 Posted : Friday, October 16, 2020 3:56:33 AM(UTC)
just double up the shortcut for the different lists under the same key
it's mentioned in the helpfiles
Multiple functions can be easily assigned to as single keyboard or controller button press.
To do this, simply add multiple shortcuts, assigning them to the same button.
manuelbotto
#3 Posted : Friday, October 16, 2020 6:22:48 AM(UTC)
manuelbotto
Italy
yes, but doing so on both lists they do me the same function at the same time. So if for example I associate nextitem with 2 lists on the same key, they move on to the next set.
#4 Posted : Friday, October 16, 2020 6:51:24 AM(UTC)
Wasn't that what you were asking for ?
manuelbotto
#5 Posted : Friday, October 16, 2020 6:57:05 AM(UTC)
manuelbotto
Italy
it would serve me that it was not contemporary.that is to be able to choose perhaps from the list editor on which list to make it work at that moment.
#6 Posted : Friday, October 16, 2020 7:00:50 AM(UTC)
as i understand it now you need a separate prev/next for each list which is the logical thing to do . that's how you choose between the 2 lists
manuelbotto on 10/16/2020(UTC)
Guest (4)
