shortcuts netitem and previusitem
shortcuts nextitem and previusitem, is it possible to somehow make it active for multiple lists?
just double up the shortcut for the different lists under the same key it's mentioned in the helpfiles Quote:Multiple functions can be easily assigned to as single keyboard or controller button press. To do this, simply add multiple shortcuts, assigning them to the same button.
yes, but doing so on both lists they do me the same function at the same time. So if for example I associate nextitem with 2 lists on the same key, they move on to the next set.
Originally Posted by: manuelbotto  yes, but doing so on both lists they do me the same function at the same time. So if for example I associate nextitem with 2 lists on the same key, they move on to the next set. Wasn't that what you were asking for ?
it would serve me that it was not contemporary.that is to be able to choose perhaps from the list editor on which list to make it work at that moment.
Originally Posted by: manuelbotto  it would serve me that it was not contemporary.that is to be able to choose perhaps from the list editor on which list to make it work at that moment. as i understand it now you need a separate prev/next for each list which is the logical thing to do . that's how you choose between the 2 lists
