Statman
#1 Posted : Thursday, October 15, 2020 11:43:57 PM(UTC)
Statman
I am new to streaming and vMix. I have built a computer with DeckLink Mini Recorder and am trying to connect to an Avipas 1080 with SDI interface. vMix recognizes the DeckLink Mini Recorder and I can control the camera using vMix by connecting directly to it. Unfortunately I cannot see a picture. The SDI cable is a new commercially manufactured cable. I don't have a way to test it. The Avipas manual is virtually useless. I would greatly appreciate any suggestions, especially about the correct parameters to set on the camera and in vMix. I have read all the posts on this forum that searching for Avipas yields.
dmwkr
#2 Posted : Friday, October 16, 2020 1:10:12 AM(UTC)
dmwkr
Was thanked: 131 time(s) in 119 post(s)
Quick guess: I know the Decklink Mini Recorder supports a framerate of only up to 30 fps on 1080p. Don't know about Avipas cameras, but make sure you only run it on 1080p30 fps, not on 1080p50 or 60.
elvis55
#3 Posted : Friday, October 16, 2020 1:42:38 AM(UTC)
elvis55
Switzerland
Was thanked: 56 time(s) in 50 post(s)
Decklink Mini Recorder:
Video Standards
SD Video Standards
525i59.94 NTSC, 625i50 PAL
HD Video Standards
720p50, 720p59.94, 720p60
1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30, 1080PsF23.98, 1080PsF24, 1080PsF25, 1080PsF29.97, 1080PsF30
1080i50, 1080i59.94, 1080i60
DeckLink Mini Recorder 4K:
Video Standards
SD Video Standards
HD Video Standards
1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30, 1080p50, 1080p59.94, 1080p60
2K Video Standards (SDI ONLY)
2K DCI 23.98p, 2K DCI 24p, 2K DCI 25p
2K DCI 23.98PsF, 2K DCI 24PsF, 2K DCI F25PsF
Ultra HD Video Standards
2160p23.98, 2160p24, 2160p25, 2160p29.97, 2160p30
4K DCI Video Standards
4K DCI 23.98p, 4K DCI 24p, 4K DCI 25p.
zenvideo
#4 Posted : Friday, October 16, 2020 2:09:19 AM(UTC)
zenvideo
You can test the SDI connection into the MiniRecorder card by using Blackmagic's Media Express app which is a part of the Desktop Video package. That should be your first step to establish the signal format before applying the same settings to the Camera input within vMix. If you can't get a picture into Media Express then you can't expect it to work in vMix.
Statman
#5 Posted : Friday, October 16, 2020 4:34:10 AM(UTC)
Statman
Thanks for the quick responses. I had both vMix and the AV-1080 set for 1080p30. I have been unable to get a picture on Media Express so will try to find a shorter SDI cable to test. I will also try to find adapters so my current test equipment can do a continuity test on my 50 ft SDI cable.
Statman
#6 Posted : Sunday, October 18, 2020 11:58:42 PM(UTC)
Statman
I was able to get another cable to try that. The original cable was defective. The problem is solved.
