vMix seem does not give XML respons properly
Joined: 8/22/2020(UTC) Posts: 10  Location: Depok, West Java Was thanked: 7 time(s) in 4 post(s)
Hi .... i dont know if it is a bug or not Maybe someone here could explain about my case I'm create a text field with multi line inside it Then I put text inside it like this Matt Aaron Taylor Jeffrey Kawika Daniel Micah Maxwell Benjamin Jake Case 1 when i request XML to vMix ----> Request: XML\r\n Then vMix give this repons (vMixRespons 1.xml)unproper XML Quote:<vmix><version>23.0.0.60</version><edition>Trial</edition><inputs><input key="d220e090-2e46-4929-b552-531c6530d175" number="1" type="GT" title="CT2.gtzip" shortTitle="CT2.gtzip" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">CT2.gtzip<text index="0" name="KANAN.Text">Matt
Case 2 Then when i delete all the text inside multi line text field and I request XML to vMix ----> Request: XML\r\n vMix give this respons (vMixRespons 1.xml)Proper XML Quote:<vmix><version>23.0.0.60</version><edition>Trial</edition><inputs><input key="d220e090-2e46-4929-b552-531c6530d175" number="1" type="GT" title="CT2.gtzip" shortTitle="CT2.gtzip" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">CT2.gtzip<text index="0" name="KANAN.Text"></text><text index="1" name="KIRI.Text"></text></input><input key="0baff97f-9502-42b5-a688-4241e74e1d60" number="2" type="Colour" title="Colour Bars" shortTitle="Colour Bars" state="Paused" position="0" duration="0" loop="False">Colour Bars</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="1000" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Wipe" duration="1000" /><transition number="4" effect="CubeZoom" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>
Case 1 It seem vMix does not feed proper XML I think vMix need to give XML character entity for CRLF all comment would be apreciate Best Regarads Gilar Kadarsah NOTE: I'm using vMix Trial 23.0.0.60 x64
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
The code you are using to read the XML, is stopping at the first line. You will need to read all the data in order to see everything.
If you are using the TCP API, it notes the full length of the XML to read as per the documentation.
Originally Posted by: admin  The code you are using to read the XML, is stopping at the first line. You will need to read all the data in order to see everything.
If you are using the TCP API, it notes the full length of the XML to read as per the documentation. Hi thanks for replay ... i will check my TCP code
