gilar
#1 Posted : Wednesday, October 14, 2020 11:24:22 AM(UTC)
gilar
Indonesia
Was thanked: 7 time(s) in 4 post(s)
Hi .... i dont know if it is a bug or not
Maybe someone here could explain about my case
I'm create a text field with multi line inside it
Then I put text inside it like this
Matt
Aaron
Taylor
Jeffrey
Kawika
Daniel
Micah
Maxwell
Benjamin
Jake
Case 1
when i request XML to vMix ----> Request: XML\r\n
Then vMix give this repons (vMixRespons 1.xml)
unproper XML
<vmix><version>23.0.0.60</version><edition>Trial</edition><inputs><input key="d220e090-2e46-4929-b552-531c6530d175" number="1" type="GT" title="CT2.gtzip" shortTitle="CT2.gtzip" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">CT2.gtzip<text index="0" name="KANAN.Text">Matt
Case 2
Then when i delete all the text inside multi line text field and I request XML to vMix ----> Request: XML\r\n
vMix give this respons (vMixRespons 1.xml)
Proper XML
<vmix><version>23.0.0.60</version><edition>Trial</edition><inputs><input key="d220e090-2e46-4929-b552-531c6530d175" number="1" type="GT" title="CT2.gtzip" shortTitle="CT2.gtzip" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">CT2.gtzip<text index="0" name="KANAN.Text"></text><text index="1" name="KIRI.Text"></text></input><input key="0baff97f-9502-42b5-a688-4241e74e1d60" number="2" type="Colour" title="Colour Bars" shortTitle="Colour Bars" state="Paused" position="0" duration="0" loop="False">Colour Bars</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="1000" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Wipe" duration="1000" /><transition number="4" effect="CubeZoom" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>False</fullscreen><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>
Case 1
It seem vMix does not feed proper XML
I think vMix need to give XML character entity for CRLF
all comment would be apreciate
Best Regarads
Gilar Kadarsah
NOTE:
I'm using vMix Trial 23.0.0.60 x64
#2 Posted : Wednesday, October 14, 2020 11:37:52 AM(UTC)
The code you are using to read the XML, is stopping at the first line.
You will need to read all the data in order to see everything.
If you are using the TCP API, it notes the full length of the XML to read as per the documentation.
gilar
#3 Posted : Wednesday, October 14, 2020 11:42:26 AM(UTC)
gilar
Indonesia
Hi thanks for replay ... i will check my TCP code
