Hello all,
Vmix crashed on me for the first time yesterday. It wasn't the best timing ;) I did some research on the forum and discovered Event Viewer. There are two errors at the time of the crash. I could use some help understanding what exactly the report is telling me.
Error 1: Faulting application name: vMix64.exe, version: 23.0.0.58, time stamp: 0x5ef060dc Faulting module name: mscorwks.dll, version: 2.0.50727.9151, time stamp: 0x5e75a06b Exception code: 0xc0000005 Fault offset: 0x00000000001c49b2 Faulting process id: 0x%9 Faulting application start time: 0x%10 Faulting application path: %11 Faulting module path: %12 Report Id: %13 Faulting package full name: %14 Faulting package-relative application ID: %15
Error 2: .NET Runtime version 2.0.50727.9151 - Fatal Execution Engine Error (00007FFEA2216D4E) (80131506)
Joined: 1/13/2010(UTC) Posts: 5,335  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
Hi, This is a very rare error caused by some component on the system corrupting vMix memory. Could be one of the inputs, a capture device or some other cause (such as a bad VST3 plugin) If you are able replicate/cause this error consistently, please drop us an email and we can help fix it: https://www.vmix.com/contact-us.aspxRegards, Martin vMix
Joined: 2/13/2020(UTC) Posts: 11  Location: Bucharest Thanks: 4 times
Thanks Hello @dobrodt, I see your error was few months ago... Do you fix this problem? HOW!!?? I have last week the same error like you (vMix stop without any reason or message): Error 1: Faulting application name: vMix64.exe, version: 23.0.0.58 (I have 23.0.0.60), time stamp: 0x5ef060dc - another value for me Faulting module name: mscorwks.dll, version: 2.0.50727.9151, time stamp: 0x5e75a06b - another value for me Exception code: 0xc0000005 Fault offset: 0x00000000001c49b2 Faulting process id: 0x%9 Faulting application start time: 0x%10 Faulting application path: %11 Faulting module path: %12 Report Id: %13 Faulting package full name: %14 Faulting package-relative application ID: %15 Error 2: .NET Runtime version 2.0.50727.9151 - Fatal Execution Engine Error (00007FFEA2216D4E) (80131506)
Joined: 8/31/2015(UTC) Posts: 31   Location: Romania Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: rss  Ce Windows folosești? Eu nu am întâlnit eroarea asta până acum. Pe site-ul Microsoft unii spun că este o problemă la sistemul de operare alții la compatibilitatea aplicația în sine cu .NET Framework 2 în Windows.
Hi What was the solution to getting this fixed? We've had multiple vmix crashes over the last few weeks, and have looked in the logs and this is the same message we seem to be having.
Faulting application name: vMix64.exe, version: 24.0.0.49, time stamp: 0x6045c6c8 Faulting module name: mscorwks.dll, version: 2.0.50727.9151, time stamp: 0x5e75a06b Exception code: 0xc0000005 Fault offset: 0x00000000001c49b2 Faulting process ID: 0x%9 Faulting application start time: 0x%10 Faulting application path: %11 Faulting module path: %12 Report ID: %13 Faulting package full name: %14 Faulting package-relative application ID: %15
