Trilback
#1 Posted : Tuesday, October 13, 2020 11:23:07 AM(UTC)
Trilback
I am doing an event on Sunday and was wondering if there is a way to create a shortcut that when I send a PowerPoint presentation or video to program that is shows on my second monitor that I have hooked up but do not want anyting else but those two to show up on my second full screen output
dmwkr
#2 Posted : Friday, October 16, 2020 7:02:29 AM(UTC)
dmwkr
One way could be:
- Create a black color input and use it as the standard output of your full screen output
- Use triggers OnTransitionIn and Out on your Powerpoint and video inputs to SetOutputFullscreen2
- Might get tricky if you are sending Powerpoint and video back to back
ask
#3 Posted : Friday, October 16, 2020 7:39:09 AM(UTC)
ask
The way I do this is to set the fullscreen output to Preview (or the input itself). Then I load the Powerpoint input into preview and configure some shortcuts to advance/back stepo through the slides. This means that I can have the main output via NDI to feed into Zoom/Teams etc., then using a Zoom Screen Share of the 2nd monitor to share the slides.
