Joined: 9/4/2011(UTC) Posts: 15  Location: South Africa Was thanked: 2 time(s) in 2 post(s)
Hi All
Can anyone tell me if you can sent the vMix out put to fire wire? I have tried , it sees the output under decklink but reports that there ia a filter missing...
Firewire output is not supported.
Martin vMix
Thanks Martin
That is a Problem for me as I use a Sony dsr 45 with Firewire in, to record to when ]tape[ recording is required. I am seriously looking at getting your software to do my Television productions with, in South Africa. So far it is looking very promising and well done with vMix. Would you recommend vMix for TV broadcast??
Regards Barend
Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
Hi Barend,
You'd probably be better off using the YUV component out from your camera and input to your PC via a Blackmagic Intensity pro, or similar.
Firewire is compressed in the camera so needs to be uncompressed by the PC before it can be processed.
The BMI Pro is relatively cheap, $150 or so on ebay, and works well in full HD so is somewhat future-proof.
Regards Brian
