28 Pages<12345>»
mtone
#41 Posted : Monday, August 24, 2020 2:48:56 AM(UTC)
mtone
i only want to use it with virtual PTZ not actual cameras.. i heard Martin say with hardware this cant be done but i thought it might be possible with virtual PTZ as its just software ?
a long time ago i had an arduino and i managed to get this ramp effect working for zoom over LANC to a sony camera and it looked good.. it took me ages and what i did was very hacked together but it did work.. my coding skills are novice at best so if you have any suggestions for the code i could try i would appreciate any help..
#42 Posted : Monday, August 24, 2020 5:05:52 AM(UTC)
I had a look at the existing available functions and current status optionds and highly doubt it would be possible within the vMix scripting
Doesn't mean it would not be possible with external scripting but i doubt it, you might think it would be only software but you will need to interface with hardware to ( joystick)
Question also is it worth the effort for limited result ?
on another note , would have been nice to have started this subject/discussion in a separate posting rather than a post aimed at giving general coding tidbits
Instafeed
#43 Posted : Wednesday, October 7, 2020 6:08:08 AM(UTC)
Instafeed
Estonia
Hello! Is there any options to update stream settings via Web API? Can't find any methods in api to do that. Its impossible at this moment?
#44 Posted : Wednesday, October 7, 2020 11:16:42 AM(UTC)
No, correct, correct, why ?
Crash
#45 Posted : Friday, October 23, 2020 11:42:59 AM(UTC)
Crash
Going down the rabbit hole that is Vmix capabilities. I had an idea when it comes to Data Sources and linking to 'SetImage' command depending on what the data states.
Basically I have ingested data and I would like to make a script that looks at a particular string and then sets the image in another data source depending on the string.
I already have all my data ingested properly, it's the 'SetImage' capabilities I'm unsure of to check data and creating an a trigger from that.
Any insight is helpful, much appreciated.
#46 Posted : Friday, October 23, 2020 3:40:21 PM(UTC)
you want to put an image into another data source based on a first data source ? or are you trying to display an image say based on its name or so ?
Crash
#47 Posted : Sunday, October 25, 2020 2:52:33 PM(UTC)
Crash
I'm trying to control the Image via what another Data Source is asking for.
Example:
Data Source 1 = "Red"
Image Source = Red Square Picture
#48 Posted : Sunday, October 25, 2020 5:54:21 PM(UTC)
Example:
https://forums.vmix.com/...with-extern-data-sources
Similar when using a script , get the "Red" and translate it to your needs
FrankLeggett
#49 Posted : Tuesday, October 27, 2020 8:17:44 PM(UTC)
FrankLeggett
Hi, as suggested by Doggy I am posting this simple VB.net code that I have created thanks to help on this forum.
The code is for a Title which has 6 pages that I want to loop through.
dim x as integer
Dim Index as integer =0
Do while Index <=100
for x = 1 to 6
sleep(10000)
api.Function("SelectIndex",Input:="Test.gtxml",Value:=x)
next x
index +=1
loop
I then added 2 shortcuts using the function "StartScript" and "StopScript" to control it.
thanks 2 users thanked FrankLeggett for this useful post.
doggy on 10/27/2020(UTC), studiodelta on 4/13/2021(UTC)
svetotehnik
#50 Posted : Friday, November 6, 2020 7:23:34 PM(UTC)
svetotehnik
Russian Federation
Hi!
How to get state of Input's MultiView Overlay?
and to create condition, based on this state?
for example if now Overlay 1 is "Green" - change it to "Blue":
API.Function("SetMultiViewOverlay",Input:="InputOne",Value:="1,Blue")
and vice versa, if its "Blue" - change it to "Green":
API.Function("SetMultiViewOverlay",Input:="InputOne",Value:="1,Green")
Thank you!
#51 Posted : Friday, November 6, 2020 7:48:40 PM(UTC)
Originally Posted by: svetotehnik Go to Quoted Post
Hi!
Thank you!
Check the Overlay @ index x of the input for the Key to match the used input key from the API XML
svetotehnik
#52 Posted : Friday, November 6, 2020 8:42:59 PM(UTC)
svetotehnik
Russian Federation
Thanks for answer!
Where is my mistake(s)?
Condition does not works
Code:
dim xml as string = API.XML()
dim input_one_state as string = ""
x.loadxml(xml)
input_one_state = (x.SelectSingleNode("//input[@overlay='0']/@key").Value)
if (input_one_state = '1f9776fd-ea21-4ef3-90ab-a45abc073296')
else
return
end if
and could you recommend some guide for navigation in xml?
FrankLeggett
#53 Posted : Wednesday, November 11, 2020 8:00:32 AM(UTC)
FrankLeggett
How to loop DataSourceSelectRow (Answer supplied by Doggy)
dim x as integer
'API.Function("PreviewInput",Input:="race1.mp4")
for x = 1 to 5
api.Function("DataSourceSelectRow",Value:="Excel Workbook,Sheet," & x.tostring)sleep(10000)
next x
index +=1
loop
#54 Posted : Wednesday, November 11, 2020 8:29:47 AM(UTC)
And could you recommend some guide for navigation in xml?
https://www.w3schools.com/xml/xpath_syntax.asp
svetotehnik on 11/12/2020(UTC)
Zen Den
#55 Posted : Thursday, November 12, 2020 2:25:40 AM(UTC)
Zen Den
Canada
I would like to thank anyone who posted here. Really useful information, links that many "dummies" can use.
Thank you, guys
thanks 1 user thanked Zen Den for this useful post.
RingsideReport on 7/15/2022(UTC)
svetotehnik
#56 Posted : Thursday, November 12, 2020 6:05:00 AM(UTC)
svetotehnik
Russian Federation
Thank you!
rajputaman04
#57 Posted : Friday, November 20, 2020 5:49:50 PM(UTC)
rajputaman04
India
I'm really stuck on a little script that I wrote to fade in/out an input with the alpha value. mxplayer pc
#58 Posted : Friday, November 20, 2020 6:55:09 PM(UTC)
So are we , would say due to lack of information
thanks 2 users thanked doggy for this useful post.
Pepsi(~) on 11/21/2020(UTC), RingsideReport on 7/15/2022(UTC)
Chris Daum
#59 Posted : Tuesday, November 24, 2020 2:35:30 AM(UTC)
Chris Daum
Germany
Hi Folks,
I am new at this forum and new in vmix scripting.
I (due to an actual situation) would like to adjust
the x position of a certain Input stepwise to the left or right.
so my idea is to programm (in my language)
- take actual position of input2
- add (or substract) 0,1 to/from actual position
#60 Posted : Tuesday, November 24, 2020 2:41:13 AM(UTC)
Hi Chris and welcome to vMix
Finally switched to vMix after so many years with ATEMs?
Check vMix API : https://www.vmix.com/hel...utFunctionReference.html
SetPanX is the command you're looking for
Guest (10)
28 Pages<12345>»
